Accuscore plus not scoring second ball
  • Accuscore plus not scoring second ball
    Hi Guys
    As title describes pretty much, on lanes 1, first bowlers to go on, it will score the first ball fine but fails to register the second ball, (cycles as it should) and it will be like this for a while but then all of a sudden it will sort itself out and start scoring and be fine for the rest of the day, lane 2 seems to be scoring absolutely fine with no issues,micro switch seems fine, could it be an MP chassis issue? not at work so cant check til tomorrow but its puzzling me as i have never come across this before in my 10 yrs as a tech! and ideas??????
    Cheers
    Dave
    You need voltage and possibly the bulb working for Accu + to score on 2nd ball - check the wires going to the #2 bulb light or mask board
      As above, check all mask unit wiring, depending on your setup.. but you should have an APS cable from accuscore either piggybacked or for later mask units terminals on the board...
        we had mp chassis do this once.. turned out to be bad solder joint under pc board. Needless to say we sent if off to find that out.
