Double Strike
  • Double Strike
    Hello,
    Need alittle help... Have Boss scoring not sure of software or anything.. but on lanes 21 & 22 it gives a double strike. This happens with it in open or league play, one bowler or six. We have changed out the CPU and MI box with another lane and the problem has stayed on 21&22. I have adjusted the micro switches, checked for bad wires all seem fine. Other than the double Strike it scores perfect. Any help would be great on this....
    Hmmm I should bowl there to get higher scores......I need them....
    --- SteveJT66
    82/70's,kickers,Kegel Kustodian
      Does it happen on both lanes at the same time?
      Regards,
      Billy T
      [email protected]
        ok guys up date on this.... Found out that BT board was bad... Replaced board problem solved ... Thanks for your help!!!!!
          The BT board caused it to score a X twice? Very strange- I wonder how that happens.
            Things that make you go hmmmmmmmmm.
            Charley
              The issue could have been the machine type switch. It makes all the difference with timing of scoring on a machine with only a sweep switch vs the switch cluster. The machine type switch is on the BT board, next to the lane numbers and server type..
                You may be able to resurrect the functionality of that board by spinning the switches
                Regards,
                Billy T
                [email protected]
                  Forgot to mention that.
                  Sometimes it's on one lane where in league play it may be reported by bowlers to be both lanes, but a relatively common issue is a deck jam cable tugging on the switch during cycle, momentarily breaking the 24 volts that keeps the machine on. I've seen is so quick, you hardly notice, but the scoring notices and gives a double score. Never seen on both lanes of a pair though. Yes I said never - I'VE never........
