Id like to make a step by step with pictures once i've completed the conversion since this seems to be a common problem during the conversion from what ive been searching on BowlTech here.
Accuscore Plus LCD conversion using Jammaboard
I seem to have hit a bump in the road when it comes to converting my Accuscore Plus monitors to our new LCD Flatscreens. I am converting the CGA signal to VGA using a converter board from JammaBoards (http://www.jammaboards.com/store/cga...-gbs-8220.html) using the method discussed by Bowltech's member RD (http://www.bowltech.com/forums/showt...540#post297540). I am working with the cords coming from the splitter board between the monitors (25 pin connector) and have worked those wires into the included Jammaboard harness. I am assuming I may be having an issue with the ground. No picture at all is showing on the test monitor, just a no signal text from the JammaBoard. Does anyone have any suggestions or information relating to what im working on that could help me?
Id like to make a step by step with pictures once i've completed the conversion since this seems to be a common problem during the conversion from what ive been searching on BowlTech here.Tags: None
The GBS-8220 is the "new and improved" board that is supposed to auto-detect the input signal type. I couldn't get it to work with AccuScore Plus.
I'm pretty sure that the board that rd used is an earlier (discontinued) board - the ACV-011.Last edited by deb; 06-29-2012, 05:02 AM.
