White Screen
  • White Screen
    First off, Thank you everyone that helped with my keyboard issue's (I know you will be reading this thread also ) Now my next issue is that one screen is completely white, and the other works just fine, except...after the first bowler, each other bowler gets a gutter automaticaly for the first ball...even though the machine is still in the first step. Any ideas? Oh and I know the monitor is good because I swapped them and the problem was opposite.
    ???? If you swapped them and the problem was opposite,doesn't this mean that the problem followed the monitor and the problem is in the monitor?
    If this is the case take the monitor from the last pair that you are going to fix.
    For your scoring issues just a question...Does it ever score correctly? If you are getting Zeros this usually means that the start switch is re-opening on completion of the machine cycle. Just in case you don't know the switch rests on the 10 pin sweep arm at zero degrees,you can observe it's action by cycling the machine from the chassis and making sure that the switch arm stays on the sweep link until you cycle the machine.
    70's MP/PBL/LBS,Q-Score
    Prolane Walker sport
      Keith - I think he meant he swapped the cables at the monitors - is that right?
      What kind of machines do you have?
      Hold the rest button on the CWC down for about 10 seconds and let the CWC start back up (about a minute), then recheck. Could be the CWC is bad if that doesn't clear it up. You are still in standalone mode, right?
        Yup I swapped the cable that goes into the monitor, so the good screen jumped to the white one and the white one jumped to the good one... Where is this reset button? I have 2 fuse looking things and a power switch...and it has started to score correctly...cleaned the pins also, thinking that might help, they are 13 years old after all
