Accuscore Camera Led
  • Accuscore Camera Led
    I came in today to see the Side ccw, ok, and cw led lights on in the base of the camera. Been having trouble with this pair scoring on and off for awhile. It has been working fine since replacing the micro switches in the tower cluster and the main power switch on top of the cpu. We have a2s. I turned it on and bowled it scored fine. I would just like to know what these leds mean when not in use.
    IIRC - it means there has been an error of some kind - you can clear it by flipping the run switch and lining up with targets if not scoring correctly
    If it is scoring fine ignore the LED's
      Mine are always lit until we have a power failure,then they will eventually all be on again in a week or less
      70's MP/PBL/LBS,Q-Score
      Prolane Walker sport
        Ok thank you for the quick response. It's scoring fine so I'll just let it be. I'll cross my fingers for the league tonight
          I have a page from the camera manual - I'll try to post it soon.
            That would be sweet thanks.
              Well the problem showed up again so I swapped the camera with the pair next to it. The problem moved. So the camera has the problem. I have switched everything except the wires on this pair. lol of course it's the last thing I try. So maybe those leds being lit is some kind of fatal error?
