amf xl misscore
amf xl misscore
82-30s 6525 chassis. Alley 5 misscores b4 a ball is even thrown the score is always right with a miss. I have changed out the scoring switch by the sweep unless i put in a bad switch witch i doubt it wasnt it where do i go now. Thank you.just another day in paradise!Tags: None
I'd first check to see if the red and black wires are on the right terminals on that switch - common and normal open.
Then, since it's an odd lane, the pin going through the start switch lever may be rubbing against the downsweep track bracket, causing it to stick. If it is, you can move the track bracket to the inside of the '30 frame..
