Another Boss Issue
  • Another Boss Issue
    Boss Scoring is scoring right on first ball. Also scores correct on second ball unless you spare. Every time it scores a total of 9. example.... 7/ gives you 7 2, 6/ gives you 6 3, 9/ gives you 9-... Any suggestions?
    Mark W.
    Something on the curtain causing a reflection that the camera is seeing as a pin. Could be an oil streak, a "wave" in the curtain or a bubble in the material. A shiny spot or something that could cause the camera to see something. As a test, swap the cutain with another lane and see if the issue follows the curtain. If you swap on that pair...it is possible the issue might just disappear altogether as the angle to the reflection would be different and the camera might not be able to see any longer..
      Thanks Once Again... The curtain was the culprit
      Merry Christmas!
      Mark W.
        Try swapping the curtain with another lane. I had the exact same problem a while back. The curtain was clean, but had some waves in it. The camera on that pair just seemed to be more sensative to it, and scored incorrectly on second ball only.
