AMF Monitor / RCA Conversion
Has anyone ever taken the 25-pin video connection that goes into a regular AMF monitor and converted it to an RCA connection? Someone has accomplished this with the other style of video connection - looking to see if anyone has done it with the 25-pin connection...Tags: None
Re: AMF Monitor / RCA Conversion
If it's the normal high-density VGA connector like the one you have on your PC, there are converters out there by 10+ manufacturers that will do it. They're called (obviously enough) PC-to-TV converters, or VGA-to-TV converters. I've used one from Belkin to do presentations on a TV from my laptop, and I thought it worked rather nicely.
<a href="http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=PC+TV+converter" target="_blank"><a href="http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=PC+TV+converter" target="_blank"><a href="http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=PC+TV+converter" target="_blank"><a href="http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=PC+TV+converter" target="_blank"><a href="http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=PC+TV+converter" target="_blank"><a href="http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=PC+TV+converter" target="_blank"><a href="http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=PC+TV+converter" target="_blank"><a href="http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=PC+TV+converter" target="_blank"><a href="http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=PC+TV+converter" target="_blank">http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=PC+TV+converter</a></a></a></a></a></a></a></a></a><span style="font-style: italic">Educatio est omnium efficacissima forma rebellionis</span>
Chris, the 25 pin connector not using all the 25 pins. It's still an RGB signal for the monitor and they run the sound through it as well.
Actually, you can now buy a Wells Gardner monitor that auto-senses RGB or VGA..
http://www.bowltech.com/forums/showt...053#post318053
We do seem to have interest in the subject of converting video signals.
