Accuscore XL Stand Alone Commands
  • Accuscore XL Stand Alone Commands
    Hey Everyone,
    Does anyone know where I can find a list of Accuscore XL stand alone mode commands?
    Thanks ahead,
    Eric
    I have my XL set up in standalone. Most of the commands can be done just by entering the numbers as they are displayed on the screen menu. The screen menu is user friendly, but it does take a little while to figure out what's in each sub-catagory. The only command function I have needed to use thus far is the "on" command.
    If it can't be fixed with a hammer, try a bowling pin! They're heavier and more surface area for whacking!
      Originally posted by DassleAdvisorNetwork View Post
      Hey Everyone,
      Thanks ahead,
      Eric
      do you mean in the menu or to turn the units on/off?
      amfxl on the odd lane will turn the cpu on.
      mon on either lane will turn the monitor on for that lane.
      if there are more, love to hear them.
        AccuScore XL Standalone / Keyboard Commands
        OFF Turn Scorer OFF
        ON Turn Scorer ON
        MON Turn Monitors ON
        MOF Turn Monitors OFF
        PON Turn Pinspotter ON
        POF Turn Pinspotter OFF
        CC## Change color scheme
        SV Display software version (date)
        RG Restore a game
        RA Reverse play arrows
        TV## Set TV channel 0 = OFF, 1 = ON
        AT## Set AUX TV channel 0 = OFF, 1 = ON
        VC## Set TV volume level
        PF## Set pinfall bit (FOR TESTING)
        AVON Enable AccuVision
        AVOF Disable AccuVision
        AVFO Force AccuVision ON
        AMFXL Maintenance mode
        VM# Force Video Merchandising without FD
        SK GOFO communications test
          Stolen...
            OFF Turn Scorer OFF
            ON Turn Scorer ON
            RG Restore a game
            Thanks for posting this list Deb. I use to have a list with most of those commands on it, I lost it awhile back.. Now I got a new one and it's going safe in my folder .
            "wiggle that wire see if it does anything"
              Is there a command to enable The games and frames display in stand alone
              If you don't have it, fabricate it...
