SYNC question mark on all lanes
  • SYNC question mark on all lanes
    We have a center running SYNC with yellow question marks showing on all the tablets. How do I get rid of these and what causes them. Any help is much appreciated
    Only time Ive seen the yellow question marks are at the front desk.
    This happens when a new tablet is installed, or the tablet(s) are offline.
    Check your network connections (switches) to make sure the tablets are connected to the system.
    Most systems the tablets connect in the back end switch, which connects to the switch on the overheads, then onto the server/desk/etc.
    Check your backend and overhead switches for power.
    Streamlane Mask Halo Lights
    Baddest Tool Chest In Town
    Adios, motor boater!
    Aluminum Repair and Welding
    http://aluminumrepair.com/...
    Hi, guys.
    check this jam...
    the ball stuck the table up
