Swapped a display controller and now I have no communication.
  • Swapped a display controller and now I have no communication.
    We are running vector plus and one of our display monitors kicked it. We swapped it out with our spare but now the keypads and won't communicate with the displays. I looked through the book a few time and I fell like I'm missing a really easy step, anyone have any thoughts?
    Never mind, solved. For anyone else having this issue in the future locate and .exe file on your server computer called dc-conf. From there you can scan and set all display controllers.
      Threx Thank you for the update, it will be helpful to others along the way
      Mike Wilson
      Bowl-Tech Inc.
      Streamlane Mask Halo Lights
      Baddest Tool Chest In Town
      Adios, motor boater!
      Aluminum Repair and Welding
      http://aluminumrepair.com/...
      Hi, guys.
      check this jam...
      the ball stuck the table up
