Sync and downtime
  • Sync and downtime
    Not sure how many centers are still shutdown, so I am posting this so it may help someone out.
    I fired up our Sync scoring system for the first time since probably Sept/Oct.
    All units were shut down except the server.
    Upon restarting, almost all units came up with "Duplicate Name" errors.
    At least they showed thier original IP address on each screen.
    Sync only holds IP addresses for about 30 days.
    After then it releases unused addresses back into the "available pool".
    Anyhow, I reconfigured all the units using their original IP addresses and everything was good.
