Lanes not communicating with Front Desk
  • marc
    we've had that problem here along with pinsetters to flicker on and off while cycling. we also played hell to find the problem and went thru all the things you have done. what we have found is the RJ45 patch panel was to blame. also check all the plugs and make sure all the wires are completely in their sockets, found that problem a few times also.
  • Lanes not communicating with Front Desk
    So to start I had one pair of lanes not communicating with the front desk. I've switched the hard drive and the i/o board with another pair and they work fine. Then the other day I tried a new ethernet cable back to the hub and still didn't work so I tried the new cable on another pair just to make sure that it worked and now that pair is also not communicating even when plugging it back into the original cable. Tried again on another pair and same thing that quit communicating. So now I'm lost as to what to try next. All three pair we have are not in communication now. Any suggestions? Frameworx scorers
