Sync and gs-92's with gamesetter
  • Sync and gs-92's with gamesetter
    Symptoms I'm having are overnight 2 pair of lanes have even lane on one and odd on other not coming on. Also on one of the pairs the ball lift is not coming on with the lane that is working. I have swapped all electronics from working pairs with issue not following the swap. Anyone with Brunswick Sync seen this? Even Brunswick is stumped and been 2 days so far with no news.
    Sooo... with further messing around, I unplugged the 3 pin lane power control for the affected lane from the common box and the lane came on and working as intended. Lucky find i guess. Posting this to help anyone else that may run into this issue.
    Also the Ball lift issue was from the gamesetter go figure.
    Ball Returns Shorted Out?
    Trip rocker arm
    Lower ball cushion board
    Backend motor plug
    82/70 combi motors
