Comm Lines
  • Comm Lines
    I have a pair of lanes that refuse to clear comm lines. I have changed the AC tray, the IO board and adjusted 5 volts. Brunswick says to change CPU also. Does it have to do with comms? Anything else I should check?
    Re: Comm Lines
    Tom:
    If it's AS-90, the AS-90 control board (small board below the AC board) can cause commline issues also.
    And yes, the CPU could cause comm issues. But the AS-90 board would be higher up in the order.
    Kevin
      Re: Comm Lines
      tom,
      Are your score sheets up? Or are all 4 screens a solid color?
        Re: Comm Lines
        I have that happening before and it turned out to be a bad manager contro board. PJ
          Re: Comm Lines
          The lower monitors are off and the upper monitors show just colored screens. The control board is good.
            Re: Comm Lines
            Tom:
            Just for gits and shiggles, I would swap out the whole I/O-CPU tray with the one from the next pair over and see what happens.
            Wouldn't hurt to verify that your DIP switch settings (I/O and AS90 control) are correct also, although I probably didn't need to say that.
            Will it turn on with the keyswitch??
              Re: Comm Lines
              I agree with KL Kevin, I have had this problem a couple of times lately.Once the i/o and cpu boards were bad,and my a/c board was bad on another pair.Be sure to push the overloads on ac board,and reset on controler board.A lso do a double clear.
                Re: Comm Lines
                I have had this problem caused by a poor connection before. I could get 5 volts at the io/cpu tray and 5+ at the power supply but the 90 board would still shut down. A 90 board will shut down with as little as a half a volt drop. I recrimped some molex terms. and deoxed everything else and it ran fine after that. If you dont have deox-it or deox-it gold you can use any good electronic cleaner to do the job.
                Just a suggestion if changing boards doesnt help.
                  Re: Comm Lines
                  What's a "double clear" and how do you do it with no lower monitors?
                    Re: Comm Lines
                    Tom:
                    Double clear is the CPU initialization procedure. Details on pages 62-63 of the scorer service manual, or if you don't have one, we'll post it for you.
                    I guess you didn't see in my last post ... will it turn on with the keyswitch, or not??
                      Re: Comm Lines
                      On the I/O board there is two sets of dip switches,double check the settings..On the back of the CPU board there is a little jumper board for the lowers,make sure you have good connections.
                        Re: Comm Lines
                        Key switches don't work.
                          Re: Comm Lines
                          When you turned the key ... did the power relays click in, and then nothing else happened, or did nothing happen at all??
                            Re: Comm Lines
                            Nothing happened.
                              Re: Comm Lines
                              Are the 3 red LEDs lit on the a/c board with the scorer plugged in?
                              Baddest Tool Chest In Town
                              Adios, motor boater!
                              check this jam...
                              the ball stuck the table up
