Changing from Frameworks CRT Overheads to Generic Flat Panels
  • Changing from Frameworks CRT Overheads to Generic Flat Panels
    I have a few questions Thanks in advance.
    1. How do you make a pig tail to plug into the RGM on the new flat panel that will fit the Frameworks connector?
    2. How do you overcome the technology difference of mixing analog with digital video ? (It's been my experience that it looks horrible)
    3. Is it really that cost effective , I understand the Flat Panels don't have 1/2 the service life of a CRT type display. Do you think it will make up the difference in new revenue?
    Once again thanks in advance.
    In order to make this work, you have to have a converter box. We started switching to LCD TV's last year from 27" CRT's, and the difference is unreal. It is a pricey venture, running about $2000 per pair or so, but the customers enjoy the larger screen. (we use 37") Try giving Dave Jackson from D & J Marketing a call.
      d & j marketing got a number
        found it will give them a call
        Blue A2 Rebuild
        Here are photos of the A2 that I just finished rebuilding and installing. Every single part on the machine came apart to be cleaned, painted, or replaced. All new rubber,...
        Streamlane Mask Halo Lights
        Hybrid (and EcoFriendly) Bumpers (2012)
        It's been about 10 years since we first tried this - 46 lanes and still working fine, auto air bumper cylinders on the BankShot bumpers. Here are videos of a home install with...
        Baddest Tool Chest In Town
        Adios, motor boater!
        Aluminum Repair and Welding
        http://aluminumrepair.com/...
