During league overhead color...Frameworx.
  • During league overhead color...Frameworx.
    During our league bowling, our normal colors are as follows....Game 1-Blue, Game 2-Purple, Game 3. From time to time, one league pair might display display two different colors for one game. For instance, during the second game of bowling (both screens should display purple) one lane may show purple but the other shows red. There doesn't seem to be any problems for the bowlers, but it does look a little bad.
    Also, on a possible related note, there have been some issues with scores making it back to the back office computer. If a bowler were to roll a 120, 140, and 160, the back office computer might show 120, 120, 140 OR 120, 140, 140. Our back office employee simply corrects the score, but it's beginning to be more frequent.
    Both problems above do not happen on one pair of computers, they happen across the house.
    Thanks for your help,
    JOEY
    If you are loosing one of the colors (red/green/blue) it will make the reg. color different. I have 27" wells 2000 series and the colors are on the neck board.
      The problem I am having is not a malfunction in the monitor or ceronix board. This is a problem related to programming. The color that come up "look" right, but it's not the correct colors. One monitor might show the color designated for the 3rd game, but the bowlers are really bowling the 2nd game. I might be having trouble explaining this, maybe someone else can explain better than I am.
      Thanks,
      Joey
        This sounds like a communication problem sometimes it can happen on 1 pair or multiple pairs
        thet are on the same Ethernet hub in the back.
        If it's just the 1 pair check the connection on the ethernet hub if possible try another port.
        If your losing scores from multiple pairs replace the hub.
        Also if you have the older BOCA(i think is the name) hubs replace them.
        Cause i have had this same issue with them.
        You can also try cycling the power on all your hubs in the back and see if that makes a difference.
        Hope this helps... Tim
          Have you had any recent up dates ? ( Backoffice )
          Mike
            Tim,
            That does make sense to me because it does seem to happen to different pairs of lanes on 1-32. I will try cycling the power to that hub, if no difference I will swap hubs with the other one at the high end of the house.
            Mike,
            I did update the back office early this week....I think it's like 3.7.1., but I can't remember. Some days, I forget my name, luckily I put my name on my underwear....LOL
            JOEY.
              Sometimes updates can do funny things... did you try back office reboot ?
              Mike
                I had this problem before the update was installed. In the meantime, I cycled the power to both ethernet hubs. If the problem remains, I will swap the hubs to see if the problem moves. Stay tuned....
                JOEY
                  Is it a lane that you recently used the cmos board in? Any custom settings like that get lost until you download them from the front computer.
                  Streamlane Mask Halo Lights
                  Baddest Tool Chest In Town
                  Adios, motor boater!
                  Aluminum Repair and Welding
                  http://aluminumrepair.com/...
                  Hi, guys.
                  check this jam...
                  the ball stuck the table up
