The left lane only when in notap or a foul occurs the solenoid fires late not sweeping pins. Checked 44/144 switch is adjusted properly. Solenoid and the pc board has been changed as well as the camera, processor board, and the i/o board at console.
AS-90
Did you check position of the zero switvh also?
Or is it engauging the proper time and maybe your link is not connected in back of detector
MikeDO A NEAT CLEAN JOB, AND FIX IT RIGHT THE FIRST TIME. THE ONLY WAY TO WORK.
Problem was the 0 switch. That machine's 0 cam had a large lobe and the switch was setting in the middle of the lobe moved the switch towards the rear of the lobe and everthing worked fine.
Thanks to Mastermike for sending me in the right direction.
Glad you got it....
Two types of lobes, there is one with a pointy lobe and the later ones have the large lobe
