Hey gang...I have a lane that's been bugging me today. I'm in the process of getting all of the 10th frame resets in working order as well as the no tap and such. However this lane seems to fire the nps a little late causing it to pick up the pins instead of sweeping them. The same for the 10th frame reset.
Any idea as to why it is firing the nps late. I checked it with my homemade tester and the nps fires on my command.
This system is frameworx.
If the nps is firing late, you may need to advance the timing on the 44/144° cam. Also just to mention, if your silver link is not connected, the scissors will not block out on your no tap situations.
Phil, the posts above will take care of it. I had the same issue when tweeking my stuff and it took some trial and error to make sure the scoring didn't get off kilter while moving the switch cluster cams back and forth.
