FMX Display backwards
  • FMX Display backwards
    FMX with lower monitors only and no touchscreen.
    Lane 9 is showing up on lane 10 and vice versa. With Lane 9 being displayed on lane 10, use lane 9 keypad to control the inputs. Scores show up that way also. It's like it is stuck in some kind of league play/follow the arrows mode.
    BUT it will do it even if only a single lane is assigned. If I assign lane 10, the picture shows up on 9's monitor and use lane 10 keypad for functions.......
    Anyone else seen this?
    Well just did some digging and re-reading. Removed a jumper off the console video PCB and the screens/data are back where they belong. Heads up to anyone else that might see this in the future.
