Having a problem with overhead monitor not working. AS-80
scoring system. Have changed all boards and picture tube, still nothing shows, no video or scoring.
Any help or suggestions would be greatly appreciated.
picture tube has power to it, couldn't get anything on it so we swapped everything with lane next to and and still got nothing.
changed picture tube and still nothing so i'm kinda lost right now.
OK, so we have changed all the boards, the picture tube, the cpu, checked all the wiring and still nothing. So next we are going to drop the top monitor unit and swap with the pair next to it and see what happens. Have no clue what is causing this. Will keep u informed.
So we replaced entire upper unit and everything is fine now. Must be something bad in middle console of unit we took down. Will have to try to figure out what it could be. We tested everything and were getting good readings on everything. Thanks Mark for the unit.
