When i came to work sat I had 1 pair where the scorers come on and it shows 10 frames and no arrows with no color bar. Then after every league game the pair will shut down after every game of league bowling but doesn't shut off after a game of open bowling. No matter what I do I can't get it back to the original setting. The only thing I have replaced is the hard drive after this happened. Thge scoring itself works fine I just can't seen to get it to work like the rest of the center HELP PLEASE!!!!!
Weird problem Frameworx
Is the hard drive you installed the same version of software as what you are running at your center? Did you install software when you replace hard drive? I saw this once where the scoring would come on but would not communicate with GSX machines not sure if A's would do same thing.For Sale, Parachute. Only used once, never opened, small stain.
I have A-2's the problem was there before the HD swap. Com is not a problem with the machines and Front Desk. Friday it was fine then when I came in the 4-6 frame display was 10 and the color bar and arrow was gone. Everything works but i can't get that pair to start with the 4-6 with arrows n color bar and it shuts off after every league game only!!!!! Open bowling is the same except it doesn't shut off after every game.
Might possibly have issue with mother board or I/O PCB...
Swap with known working pairs....
Are you saying lowers and uppers show that ?
I would still check the version of software in that pair just to be sure also.
MikeDO A NEAT CLEAN JOB, AND FIX IT RIGHT THE FIRST TIME. THE ONLY WAY TO WORK.
Were talking about one pair correct ?
Seems strange that would be in back office or desk being one pair...
I think you mentioned it, But have you done a back office reboot?DO A NEAT CLEAN JOB, AND FIX IT RIGHT THE FIRST TIME. THE ONLY WAY TO WORK.
No I haven't done a office reboot, when I check the settings for the frames, exciters, arrows/color bar. It shows them set accordingly but when i turn the pair on it shows no tap mode on the front desk. When i talked to Brunswick he said there might be a file error for that pair in the office pc so i am waiting for them to call back. SMH
Wow
a file error....that can send ya for a loop troubleshooting....LOL....
this happen after a back office update? I could see a file error then
Cant hurt to try a reboot, they should be once in awhile anyway...
Does it let u take it out of no tap mode?DO A NEAT CLEAN JOB, AND FIX IT RIGHT THE FIRST TIME. THE ONLY WAY TO WORK.
