as 80 lower console
  • sportlanes
    I tried two different keypads with the same results.
    Ron
  • sportlanes
    If the keypad was shorted out then would it not work also?The only time I have changed the pad when it completely quite working.
    I forgot to mention when I cut the console off and power back up and hit the clear button it will work fine until it is given back
    out again.
    Ron
  • smurtland
    But did you change out the keypad? If the keypad shorted out it could possibly cause this issue.
  • sportlanes
    I have swapped out the tray completely and the keypad seems to be working fine.
    Ron
  • MASTERMIKE
    Have you tried exchanging key pad or tray ?
    Mike
  • sportlanes
    started a topic as 80 lower console
    as 80 lower console
    I have a lower console that when you enter the names and when you push bowl the screen on the lower goes blank
    for a second and when it comes back on the names disappear and the only thing showing is the score sheet and the
    overheads are fine.Any ideas what would cause this?
    Thanks Ron
