Frameworx monitor
  • Frameworx monitor
    hey guys
    was wondering at some point in some of my lanes the lane monitor just goes off
    once we tranfer the lane and then back it works again
    could anyone give me a tip or hint on what could be wroong it only does it now and again
    cheers guys
    I'd first try the monitor control board in the housing. It's the small board on the left side, above the transformer. It controls the power relay (115 to the monitor) when a signal is present.
    I'd only try that first as it's easiest to replace. But there's a good chance a component on the ceronix board is causing the fail safe circuit to shut it down as a designed.
      agree with Ted
