Vector Plus w/ Frameworx Front Desk Respots
  • Vector Plus w/ Frameworx Front Desk Respots
    Does anyone happen to know why the Respot settings at the Control Desk are not enabled for Vector Plus Office w/ Frameworx scoring?
    The way I see it is, if you enable Practice mode on the consoles (or turn them on in stand-alone) the console themselves have absolutely no problem telling the pinsetters to respot certain pins. If the control desks can talk directly to the consoles, I see no reason why it couldn't interact with these respot settings.
    That said, when I pull up the Lane Control button (which after some reading is apparently where this option SHOULD be) all I see is Pause, Resume, Mechanic Hold, Mechanic Release, Re-start Pinsetter, Re-start Bumpers, and 4 blank spots.
    Fix it the right way? You can't do that unless it worked right to begin with.
    Frameworx scoring does not have this option, this is an option for Vector scoring.
      And GS Pinsetters
