Lanes shutting off!!!!!!!!!
  • Lanes shutting off!!!!!!!!!
    33-34 since yesterday I have had to reset the breaker on the console 4 times. They start bowling league and boom the lanes shut off, and i have to reset then they come back on. Does anyone know where i need to start looking to fix or is the box just going bad?
    Check for a wire on the track. It could be a bad component, or a short when a ball rolls across the wire.
      I went from the ball lift to the pin spotter and there were no wires laying on the tracks or signs of any kinks. Next I will try going through the wiring routed through the machines. Would it be possible that the short could be in the pin setters chassis? I have converted A-2's
        Possible but doubtful. The Pinsetter interface is losing power causing the machines to turn off. Unfortunately, you also need that power for the CCD Proc and camera. check the following (after checking the wiring from the console to the pinsetter I/F):
        Check the connector (or unplug) the connector for the scanner tester inside the CCD Processor box
        CCD Processor power connector near the transformer.
        Pinsetter I/F
        CCD Processor
        Camera
        Wire between I/F and CCD Proc.
        Circuit breaker on power supply
        Power supply itself
        Good Luck......
          I will let you know what i find. I can't do anything right now, I have 48 lanes going full steam!!!! Thanks
