CCD Camera help
  • CCD Camera help
    Does anyone out there know the specs of the trasformer required to run ccd cameras through the as80 console? I am trying to switch my 86 scanners to ccd cameras. I set up a test lane but it doesn't score. I have been told the transformer in the lower console may need to be switched out. Thanks
    If it's broke it will work great.... until you stop watching it.
    Call tech support at Brunswick because I dont think AS-80 scorers can use ccd camears..only the scanners
    Chip
      Do a search type in "as80 ccd" in the search box top of the page.
      There is a lot of info on this sit it probable is not the transformer I have switch
      some of our lanes to ccd camera what soft wear is in the ccd box this makes
      a difference on the dip switch setting.
      split house8-8230kicker,4-8270pbl
      surepick
      wood
      phoenix-s
      As90
      pins 2pair w/amf,2/bruns,2/linds
        Mudman, i meant to get back to you. The transformer you need is the one out of ASK & AS90 scorers, it will bolt right in to replace existing transformer. I can get you one to try, call me. The original transformer will usually power the camera, but does not have enough power to power the CCD tester. We changed 2 centers, a 20 laner from ASK's to AS80 and just flipflopped all the transformers. We also converted T&C from Frameworks to AS80's, and left existing cameras in place. The cameras would work, but he had a bigger transformer he would have to plug in every time he had to recalibrate.
        Brent V
