help as90 prossesor
  • help as90 prossesor
    i have a pair of lanes that front end works good but prossesor keaps shuting off.
    have moved prossesor to other pair works fine ran new wire to camera switched camera still does it. the leds light up then goes back off and flashes off and on. also if you hook up scanner it kicks off and on with the leds brunswick as90 scorer new at scorers have no clue please help.
    Is it popping the breaker on the a/c board in the console or just shutting off at the processor itself?
      I'd also check for ANY loose connection OR an overtight wire on the processor assembly. If the breaker at the console keeps popping off then i'd suspect the processor transformer,i had a transformer go south.
      Had some that the wires for the processor we're waaay overthight and causing issues so i move them over for more wire slack,problems went away after that.
      Is the 5v at the console good,all wires secure?
        Trying to remember off the top of my head,
        But was there a relay also?? along with the breaker...
        Mike
          I would take power board off and check transformer for bad legs also check the capacitors.
            Billy give Don madden a call 1-951-684-2695 intergrative scoring he s awesome with as-90 .
