Classic scoring system problem
  • Classic scoring system problem
    On lanes 1 - 8 at random times the images on the monitors will lose color and leave what appears to be a "burned image" on screens..all backgrounds colors go to gray...system will still score...shut lane server down for a couple minutes and all is good till the next time which could be minutes to days...I have a rebuilt hard drive but am not sure if this is my problem..All connections have been taken loose blown out and reconnected,and did not help...Any suggestions would be appreciated..thanks Lynn
    If you have more than 8 lanes, you could swap the hard drives between 1-16. You will have to set them up as the new lanes...or you could just leave it that way for a bit (commands to 1-8 will show up on 9-16 and vice versa) and see if the issue moves with the server.
    If I remember correctly...isn't there a backup hard drive in the server? You could just switch to the backup.
    Also, you could swap just the video board but that is not something I have done in the past. I am pretty sure it can be done though.
      Sometimes the video boards (big ones near the top) work loose in the computers! Always power off before checking!
