AS80 Colorvision
  • AS80 Colorvision
    I have a center with AS80's with the big colorvision control at front desk, 25" overheads with color decode boards which do not have lane assignment switches. We were hoping to eliminate the big colorvision box and just run the overheads on default but if i unplug the overhead comline they don't work. Anyone have any suggestions?
    Brent V
    The colorvision box is used to tell the color decode board how to function. If it is not there...the board will be lost. I don't think you can get rid of it unless you go to Source Command or Command Network which will involve far more changes than you would want to do.
    Is there a reason you want to get rid of the box? Maybe there is another solution depending on why you want to remove it. Just thinking out loud...
      Thanks Steve, you confirmed my thoughts. They just want to get that monster off counter but it isn,t going to happen. P.S. Guess he could buy new system but with economy this way no dice, he could as he just won 1 mil off a $10 scratch off lottery ticket, got slightly less than half that taking lump sum after taxes.
      Brent V
        You could build a shelving system around it to sort of "hide" it. I know that box is huge and takes up a lot of space. Just a thought...
