Vector Scorer freezing up
  • Vector Scorer freezing up
    All Scorers locked up, this has been happening at least 1 or 3 times a week system is only 2 months old, have been on the horn with bruns so much that my ears are sore yesterday finely hope i got the answer bruns said that they have found some issues with the 64gb kingston solid state hard drive, they said that their is an issue with the firmware and that they will be sending out 6 new HDrives with the new firmware 60gb kingston Hdrives, Just some info in case some of you are having problems like this
    Have a bless day . . .
    Assumed you used a tester on the network cables between the server, switch and slaves? Just one of those things I'd investigate regardless of what the tech support flow charts say.
      Thanks for the heads up information Larry
        We were having issues with our solid state hard drives so much trouble in fact that we went backward in technology and switched to older style platter hard drives . We have not had any issues with scoring computers since we did.
        24 A-2's
        Brunswick Pro Lane
        Vector Scoring
        Kegel Kustodian
        Twister Pins
        Polychem oil and stripper
          Over a week now and haven't had any problems not 1 yet anyways knock on wood.
          The tech from brunswick said that they where going to be recalling the 64gb HD.
