Vector plus scoring
  • Vector plus scoring
    I get a double score for one ball thrown. Changed everything I could except cables. I have A2 machines and pair still gives me a double score.
    check your rake switches... sometimes if there is not enough clearance between the rake and the arm on the switch assembly the rake will drop and the switch will bind up on the rake momentary and double score
    24 A-2's
    Brunswick Pro Lane
    Vector Scoring
    Kegel Kustodian
    Twister Pins
    Polychem oil and stripper
      Ok, I will re try some adjustments on them. I have tried increasing and decreasing the gap on the lever, maybe I'm not quite hitting the honey spot on the pair of lanes. Ty for the advice.
        Take the cover off the camera and watch the LEDs for the switches and make sure they come on and stay on as the rake is down. Also check LEDs 19 and 20 for the ball detect.
        Since it's both lanes, I suspect it isn't the switches themselves. You have changed the camera board?
          its not actually the gap between the switch and the lever i meant the gap between the lever and the rake. also i know you said you have not changed the cables but just check them from camera to scoring computer . Wouldn't be the first time an installer didn't tie one up very well and it got damaged.
          24 A-2's
          Brunswick Pro Lane
          Vector Scoring
          Kegel Kustodian
          Twister Pins
            Do not like the switch had problems before the installer even left, anyways after he hes gone still had some to get out of adjustment just days later.
            So i changed them out with mercury switches, manager wasn't happy at 1st but after 3 weeks to now he well pleased.
            didn't remove the switch yet but do have plans to remove later . . .
