Frameworx scoring 'X'
  • Frameworx scoring 'X'
    I think this might have covered in an earlier post, but I have a lane scoring all strikes, no matter what the first ball pincount. We have Frameworx Touchworx with completely updated CenterMaster. Rebooting the LGP works for four or five frames and then back at it. Only affects one lane out of the pair. It has happened in the past and usually wind up sending in the VPS to Brunswick Repair. Just wondering if there is something I should be looking at before shipping off to Brunswick. Thanks in advance.
    I had this same problem a few months back and it turned out that
    someone had reversed wires 13 and 14 on the time delay causing no delay on first ball.
    This may not be your problem but maybe something work checking.
      A little more information to add. All LED's light correctly on VPS through first ball cycle except no pincount LED's light up at all.
        Remove the coax connectors - both at each end- and tighten the connectors by trying too turn the BNC connectors clockwise onto the coax.
        Then make sure the camera cables don't droop into the return track ball path.
        I also suspect the power supply in the processor box may be weak and fail after warming. The power supply is the board on the left of the box.
          Turned out to be coax connections. Thanks, Ted.
