tenth frame reset
  • tenth frame reset
    anyone have any problems with the tenth frame reset not working every so often. it happens to me on 3 and 4. mod a with vector plus
    <---- You are getting sleepy, very sleepy. When you wake-up you will want to bowl more. . . .
    I have seen this happen once in a while if the machine has to wait for pins. Try increasing the time for the scoring system to wait before sending the signal to cycle. Shouldn't need to go more than a second or 2 at most.
    Vector sends the signal after a set delay. If the machine is not a 0 degrees, the signal is ignored and the machine doesn't reset pins.
      all right, i will check that out. thanks.
        Why would the scorer send 10 frame reset signal when the pinsetter is at 180 waiting for pins? The only time it should send that signal is if the bowler's last ball thrown in a game is NOT a strike. After pinsetter makes its standing pins cycle and pinsetter 0 switch is engaged..then it'll start its delay..however you have it set..then cycle the pinsetter at 0 2nd ball. I agree..try incresing your time delay for this setting see what happens
        Chip
          Chip
          OK bad example. Sorry.
