Duo upgrade, monitor preference
  • Kanga (James)
    We have installed TCL TV's here in AU as suggested by Comscore. There is usually a technicians menu that allows you to alter the power up behaviour. If not there's always a way around it with a little technical know how
  • Dustinpins
    started a topic Duo upgrade, monitor preference
    Upgrading to Duo in 6-8 weeks and wondering what monitors (TV) people are using. Going with 55" (have this size in other center) and needs to come on when power is supplied not needing a remote to turn on. Any suggestions?
