Monitors switching lane numbers on same pair
  • Monitors switching lane numbers on same pair
    Currently have 2 pairs of lanes where the monitor is showing the wrong lane number on that pair. Example is that lane 1 shows lane 2 on the monitor and lane 2 is showing up as lane 1. I tried switching the HDMI cables around and it doesn't change anything. This is the Duo system.
    When I run into this issue:
    Make sure the HDMI cables are connected correctly for Odd/Even Lane. Shut down Duo. Make sure both monitors are powered on and set to HDMI input. Turn on Duo.
      I tried this and they are still switched around. I took it off line and ran through the set up, reset the Duo and they are still switched around. Strangely it doesn't matter which HDMI port I plug the cables into they stay switched around.
        This sounds like a Windows desktop issue. I don't have access to a multiple display windows setup but if you attach a mouse and move it down to the lowest-right corner of the screen and left click you will minimise the comscore lane window. Go to settings-display and see what options you have to change the main and secondary displays. There should be something there that will help you with your issue.
          It was an issue with Windows 10. Either have to be quick with the mouse during the boot up or plug in a keyboard and hit alt and windows key to get to the setup. Thanks again!!
            Glad you got it.
