Wierd scoring problem
  • Wierd scoring problem
    Tonight lane 2 only, would score 1st ball then only if you knock pins down and still had pins standing it would rescore 1st ball and not score 2nd ball. Strikes, Spares and misses on 2nd ball were OK. I am think bad wire connection some where? I have Matrix System and A machines.
    Sounds like a frame sync issue. Do you have the second ball light hooked up to the MIB? If so, is the first and second ball light switch adjusted correctly?
      No, the MIB is not connected to second ball light. And I had the second ball light checked and it is adjusted correctly. The system has not done it since that night. Wierd
