stops scoring randomlly ..
  • stops scoring randomlly ..
    have a pair of lanes that just stopped scoring mid game ,,checked camera at desk showed blank screen so figured camera board ,,swapped with new board ,turned power breaker back on ,,,worked ok for a day and did again ,,thought maybe vdb box might be heating up from bad cooling fan air ,,,vacuumed al dust from unit and surrounding areas ,,,turned power back on ,,worked for 3 weeks and center just called and said stopped scoring again ,,,,,,,,,,,,any ideas guys ,,,,,,
    update ,,,,,,once again camera screen shiowed blank ,,,,shut off power breaker and turned back on the pair booted up ok ,,no errors showing ,,,the began scoring ok again ,,,??????…..
      I would swap the VDB with one from another lane pair next. Keep track of where you swap parts to and don't swap all the parts from this pair to the same place. Copying pinsetter parameters from other lanes is moving up on my troubleshooting list as well.
        Possibly a bad cable sometimes losing its connection?
          well I guess now that im under a 2 week mandatory shut down in Michigan ,,ill have lots of time to swap vdb,,,,,but taking what little money I have to make payroll and mortgage payment ,,better not need to buy parts ,,,,,,this is crapp
          Help-broken Part
          Greeting all.
          Thanks for looking.
          Bolton454
          Pin Damage
          Making TDM's adjustable.
          Gold Crown Masking Unit
