Conqueror TV question
  • Conqueror TV question
    Currently we have LG TV's, need to replace a few.
    There are some good deals on other brands.
    Question is:
    Where in Conqueror do you setup for turning on the TV's.
    Need to change the remote code.
    Cannot find it.
    Thanks
    Before you throw those LGs out take a simple check. If you problem is no image it is probably just the LEDs which are not expensive to replace. This can be tested by shining a flashlight on the screen. If the TV is still working you will be able to see the image dimly.
      Had another on go out last night.
      Screen went black.
      On some of the other that are still working, the reflectors fell off, so there are a bunch of white lights on the screen.
      From what I've been told, the time it takes to repair these, would be less expensive to buy new TV's.
      Thanks for the reply.
        Found where to setup the TV's.
        Was right in front of me, just had to look a little harder.
