Pair acting funny
  • Pair acting funny
    At snow bowl stream boat springs Not sure if command is coming from software got the BES system here ... Pins get picked up and then shuttles if it were a strike both 1&2 changed chassies not that issue. What i am looking for to correct this problem. Little stumped
    walledup10to10 rideing the e.a.c !! you speak whale ??
    If this is in the scoring the most likely things are to upload to lanes or copy the pinsetter parameters file from working lanes. It might also be a good idea to cross post this to the relevant pinspotter forum if you haven't already.
      Camera and machine parameters
        So i understand everything signals and all go through F box to command pinsetter to cycle ? I swapped camra boards with 3/4 problem remains.. No spare on shelf to replace so i will swap with 3/4 monday
        Ball Returns Shorted Out?
        Trip rocker arm
        Lower ball cushion board
        Backend motor plug
        82/70 combi motors
