VDB replacement
  • VDB replacement
    I found a bug in the latest upgrade. The "replace VDB" tab on front desk now does nothing. I go to the "move VDB" tab and enter the VDB serial number and lane pair and it does the job, but "replace VDB" in the last version was a little faster.
    Re: VDB replacement
    first you have to get a vdb to replace the one that's bad. if that were faster...i could live with the vdb replacement icon not working
    alex
    Cloth: ShamWow!
    Machine: Johnny 5
    Help-broken Part
    Greeting all.
    Thanks for looking.
    Bolton454
    Pin Damage
    Making TDM's adjustable.
    1:1 shaft wear
