Can anyone give me some imformation on what I need to go to flat screens. We have Qubica Scoring.
Replacing 34 inch monitors with flat screens
Smits,what you think,you have pcboard convertion or try only with one cable one side have db9 and other need db 15 conector if you think only the cable with out pc convertion not work take care becosue you can damage VDB.
are in some web site how you can make this cable but Not work.we try in laboratory make this and dont good result.try with,box convertion from qubica amf or other suplier work very fine.
jesus
These guys (they are in Australia, but will ship O/S) make a converter for VDB's to work with LCD's and plasmas - 9 pin D-Sub -> 15 pin D-Sub. They're pretty good to deal with and will be able to help you out with it if you shoot them an email or give them a call! They can also supply screens and hanging brackets etc etc...
http://www.cybernetic.com.au/product...converter.html
The QAMF gear is quite good now too, but it's relatively expensive and they may want to sell you new VDB's too - you'd have to call and ask!
Andrew
Graeme at Cybernetics says that their converter may not work on cheap domestic screens but at the price the converter is it is worth a try. The QAMF converter is around the $1000 mark here in OZ but works fine on all screens.We have used them at Logan City and Surfers Paradise.Regards,
Len.
On VDB 99 you have a VGA output.You need to make an cable from VGA connector to an SCART one.
Check this links to get info:http://www.idiots.org.uk/vga_rgb_scart/ , http://www.epanorama.net/circuits/vg...b_pinouts.html ,http://pinouts.ru/Video/VGA15.shtml
Hope is useful.
I made some cables a few years a go , but don't find the wiring diagram.I remember i put some resistors on a few wires ...but don't remember now.
