we have quibica scoring with 82-90xl and the out of range is getting to be annoying. the gutter and 7 n 10 pick off work fine just not the out of range. i need to know if it is the scoring or a chassis issues.
help with auto out of ranges
There are two spec codes involved. Mike (or Jamie) from Stahl's mentioned sweep reverse which is set with spec code 32 (33 to disable), and spec code 25 enables auto off spot release. The spec 25 setting will make the sweep reverse to home when an off spot occurs (if the switch and wiring are good). With the normal off spot function (spec 26), the sweep stays at first guard and the table returns to home awaiting a technician to clear the problem.
