Does anyone know what the distance should be from the camera to the sweep or pin deck or whatever it is the measure from during the install?
Specs Please!?!?
I don't know which cameras you have or if it makes a difference if it's the T or Q vision, but you can download the T Vision camera intallation PDF on the QA customer portal, it shows how to place the camera.
With a 10 1/2" wide return capping, you can put any camera (single camera per lane pair) at 156" from the center of the 7 -10 line to the back of the camera lens..
