scoring problems with black lights
i'm having problems with some of my lanes not scoring correctly when i turn the black lights on.. looked at the camera and the pins are visible no shadows on any of the pins. is there any thing i have to adjust to make them score correctly. i'm new to this so any help would be greatly appericatiedTags: None
I have Q Vision cameras and have not had this issue with blacklights. Well besides it being a problem with the blacklights, if the camera dots are correct there is one other adjustment on the camera you can check. On the Q Vision camera the aperature setting is supposed to be set so it is automatic and I believe this is set by turning the screw on the top of the camera all the way counter clockwise. Other than that I don't think there are any other camera adjustments, but I can't find the Q vision manual so I'm not completely sure, hopefully somebody will see this and add to it if there are.
or at a push set it extra bright in daylight, then it will allow more light in in the blacklight, so long as it still scores correctly in daylight have it as bright as you can, try it on one pair and see how it goes
or you can purchase a black light that have bl instead using the purple black lights that have blb at the end of the light discreption the bl lights are a brighter of a black light. This will help from regular light to black lights
In fact, I suspect you wouldn't even use the camera, just mount the IR camera in front of the existing camera and power it up. The IR emiters will be on.
Here is a camera supplier:
This CCTV ir day night camera can capture video in darkness mode up to 66ft away with 24 built in IR LEDs, it is weatherproof , can be used both indoor and outdoor.
$25.
