Need more focus
  • Need more focus
    I have single T-Vision camera and boards and on pair of lanes I cant get enough focus out of the camera, it is turned all one way and still the picture is not great, Is there adjustment on the board.
    Cheers Harry
    There is an adjustment on the board - I think of it as an adjustment to balance the brightness (sort of) of some cameras, mostly the older CANAM cameras I still have. For focus, there is no adjustment, except on the len. They dont really need to be crystal clear to score fine. Have you tried cleaning the lens?
    And the board adjustment is in the manual for the camera.
    Marty - Pro Bowl West
    56 Jap A-2's Qubica VDB's
    2 Kustodian Walkers
      What happens is the Internal Focus lens gets loose. If you have extended warranty, dont do this. If you dont, then disassemble the camera using 4 little black screws. There is another lens that will have come loose. there are 2 divots in the lens collar, i use the divots with a nail to tighten lens back up. Reassemble. while you have it apart, check the wire connectors, they have a habit of vibrating apart also. after that it'll be hard to make the camera Not be in focus. DisClaimer. Disassemble at own risk.
