Communication Issue Qubica
  • Communication Issue Qubica
    I have Lighting Bolts showing up on the main screen. The lanes will show up then lighting bolts will pop up and I will lose communication with the lanes. I have a green light on the interface box between to computer and the monitors. I have lights on on the router between the interface and my computer. My computer has been running slower and slower. any help would be appreciated.
    Thanks
    Steve Ludwig
    Salem Bowl
    If you aren't doing so, send the programs once a week, and check the box erase memory.
    Then, exit conqueror and run defrag in accessories/defragment hard drive.
    I'd then shut down the computer. And power it off. Then power up and boot up. See if it makes any difference.
    Power off the ET host, then power it back.
    If you only have one cat-3 home run to the VDBs, you can try the next output of the ET Host, but I suspect it'll be in the server.
    Make sure you been running shift reports and clearing them out.
    While it's off, take the CPU from its storage place and vacuum out the air intakes and all fan areas in the case. Heat can cause this.
    See if these things help.
      I agree with the above but how old is your hard drive.
