tcs failure
  • tcs failure
    2 day ago out of nowhere the tcs sent 5 blank calls through to my lane phone. After that it stopped working completely. Thought it might have been a power surge, we've been having a lot of rain. Talked to Qubica and replaced the QDAC. After doing that I can receive calls sent from the front desk computer but the lanes themselves will not call when in error (90's, 180's, blackouts). The mechanic light on the pinsetter will also not light up. Tried rebooting a few times. The QDAC reads connected at the computer. Anyone ever have this happen? Is there anything short of rewiring the whole system that I can do? I appreciate any and all help guys.
    I break it, I fix it. You break it, ... I fix it. Damn!
    check the terminitor at the end of the cat5 run
      Start by disconnecting all of the boxes and then connect one up at a time and see if that helps. If they start to work...then the one you connect and it stops working...that would be the bad one. I would start with that procedure.
        sorry about the delayed response guys. giles/steve thank you for the help. the back end box for lanes 1&2 was bad. now we're just waiting on the replacement.
