I have qubica scoring with bowland x, conqueror, and Brunswick A-2's. My problem is that when lanes are turned on whether with scoring or just mechanics switch, they will have thier cycle solenoid plunger engaged in the up position. The machines will just constantly cycle. The problem will always happen, but it is intermittent. When the lanes are turned on it may take a couple balls or minutes and then one lane will constant cycle, then the other at the same time on that pair (27/28). My machines have the rake switches bypassed after qubica was installed.
What i have done so far to try and figure out the problem (i had spares of all these components)
Changed VDB
Changed six box
Swapped t vision board with another lane
Disconnected reset button from up front
One thing i did to try and see if it would work, was to disconnect power from the vdb and see if the lanes will stop triggering (still turned on by mechanics switch) and they did. As soon as i removed power from the vdb the lanes stopped constant cycle. Even more cooky is when you turn off scoring by conqueror for the pair, and go in back and turn them on via mechanics switch they will engage the cycle solenoid as soon as power is applied.
All of this data, to my knowledge points to the scoring some how... lol Please advise
Dan
