Odd lanes cycles but won't score
  • Odd lanes cycles but won't score
    82-70 XLI upgrades, Black Single Chassis, 3QTs, Q Vision Camera's, Conqueror Pro.
    Odd lane cycles but will not score. Rebooted with memory wipe. swapped Q Vision board & block camera lense. Swapped 3 QT and black chassis. Swapped ball detector (mine are separate from Camera) Tested Keyboard, all letters work. Put on hold for Thanksgiving break with permission lol. Plan tomorrow is too copy pinsetter parameters from working machine, swap whole camera assembly and keyboard.. and then call tech support because I'm out of ideas, any thoughts on anything else I should check would be appreciated
    If you enter a 1st ball score by hand...put pinspotter on 2nd ball and then throw a ball...does it score?
      No it didn't because I learned today that even if the sensors on the camera are only used for ball speed if one of them stops working the machine will cycle but not score. Weird but very useful thing to know.
        Ours will still score...just won't display ball speed. Interesting.
          Did someone tell you this or is that what you have actually found out ? I am with Steve on this, one ball detector out of alignment should just cause the ball speed to disappear but the scoring should function fine with just one (it may cause the cycle time to be extended though)
          Marty - Pro Bowl West
          56 Jap A-2's Qubica VDB's
          2 Kustodian Walkers
            I see no mention of it being verified that all of the ball detectors work properly.
              That's exactly what it was Tablejam. The detector wasn't working at all, replaced it, problem fixed. Threw me for a loop because we have seperate detectors to trigger the machines
                Damn electronics!
